Smitty77's avatar
Smitty77
Balanced Charging X's 4 6V Batteries
As I've recently started a campaign returning to basics on the care and feeding of my soon to be replaces X's 4 L16's - I have a follow up question.
I've confirmed proper wiring to yield parallel/series, with appropriate and good quality cables.
It was the placement of the Magnum Charger and MidNite Controller charge cable feeds that does not match my research on obtaining balanced charging.
Iota has a nice (Diagrams, makes it easy for a back to basics sanity check!) write up on balanced vs non balanced charging.
My current Magnum and MidNite charge feeds are in a 'non balanced' method. However, when I was getting help here and elsewhere on trying to save my battery bank. I took several multi meter voltage readings of the full bank, and the four individual batteries. And noted. less then a tenth variances in the voltage.
Iota does talk about Amps vs Voltage in their diagrams. So please forgive this question. Does practically balanced voltage at each battery while under charge, equate to balanced amps too?
With a bank of 4 6V batteries vs say 6, 8, etc. - what is the recommended 'Best Practices' for obtaining balanced charging?
TIA, and best to all,
Smitty
PS: OK to say reading too much into this, and not to worry about it...
  • Boon Docker wrote:
    The diagram above will not work with GC-2 (6 volt) batteries.
    I believe that you're referring to the two diagrams that "red31" posted above your earlier post.
    The left diagram above your earlier post represents four (4) 12 volt batteries connected in parallel in a balanced way.
    The right diagram above your earlier post represents eight (8) 6 volt batteries connected in series-parallel to makeup four (4) "12 volt batteries" connected in parallel in a balanced way. (Notice the little black line at an angle in each black outline box - that outline box represents a couple of 6 volt batteries interconnected in series.)
    Connecting batteries together in a "balanced way" is not Rocket Science. All it means is that the total wire length (regardless of what wire size is used) going all the way around the loop from each battery's plus terminal to it's minus terminal is the same length for each battery. With a balanced setup, this "same loop length" for each battery will be the identical for every battery whether the battery bank is being discharged while feeding the RV's total electrical load or being charged while being fed by the RV's charging equipment.
    The object is for all battery system cabling voltage drops (regardless of cabling gage size used) from currents going to/from each battery to be the same - as seen by each battery.
    Balancing the battery bank this way is of course external balancing ... and does not ensure that internal battery construction and chemistry maintains balance at all times internally between the cells within each battery during the life of the battery.
  • "I believe that you're referring to the two diagrams that "red31" posted above your earlier post."
    Yes, the first diagram (on the left) before the edit.
  • The FREE Lifeline battery PDF download has pages of correctly assembled series and paralleled batteries. More batteries and more series configurations than you can imagine.
    The connection diagram is valid for all types of batteries not just AGM.
  • MEXICOWANDERER wrote:
    I IR shoot the entire bank after 400+ amp recharging for >20 minutes.
    At that rate, any misalignment between the face of the terminal and the battery cable end will WELD the dissimilar metals together ! :B
  • It is unforgiving -- utterly.
    Taking a mill file to a battery "L-Pad" then to a terminal, to insure both a absolutely flat made a significant difference in terminal to L-Pad interface temperature. Getting the mounting pad flat on the Trace 4024 was challenging. They were concave. A use friend loaned me a mill cutter with a 1/2" arbol hole and will no small amount of effort I dressed the pads.
    A vise, a large mill file or bast(a)rd if the surface is rough can really flatten the irregularities on a lug.
    9,000 watts is a lot of energy...
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
