BFL13's avatar
BFL13
Explorer II
Apr 27, 2018
Bank These Batteries? UPDATE
Updated 28 April
(Changed topic so starting new thread)
Now I need an opinion/facts if I can bank this big one with my two smaller AGMs even though they have different "cycle use" charging specs (lower 14s vs higher 14s) They do have the same Floating specs.
If I did, then I would be running inverter loads on the 450AH bank too. Now I use the two 100s for inverter and the 250 separately for the rest of the 12v stuff.
A. Just bank them and discharge and recharge them all at once
B. Bank them only for discharge and recharge separately
C. Leave them separate the way they are now (means usually getting the big one down to 50% while there is still lots left in the inverter's bank)
This big AGM seems to have been built at or next door by the same factory as my two 100AH AGMs. They even have exactly the same carrying handles. Their spec sheets/graphs are written to the same format.
Here are the two spec links again--
EDIT--had the the wrong link for the big one, sorry! Mine is the ESG with 14.1 to 14.4 for cycle use, but the other link has the same other specs. (it would be too easy if these two 6GFMs were in fact the same battery and had the 14.8--)
http://www.esg100.com/index.php/product/index/g/e/id/35.html
http://www.wegosolar.com/products.php?product=SKR%252d125AGM-Stark-AGM-12V-Solar-Battery-Sealed-125A
http://cn.yahengpower.com/data/upload/file/201612/8b4d4c59da39f4428b9ff79f380ab271.pdf
BTW, bestconverters is selling that "Stark" one (mine are actually 121 100AH but wegosolar has now gone to the 125 version--same specs) as a "UPG" brand. (They seems to all come from that same factory in Canton :) )
http://www.bestconverter.com/UB121000-100-AH-Deep-Cycle-_p_293.html#.WuJQYlKWxLM
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
