jergeod
Aug 03, 2022Explorer
Barbecue hookup
Am I missing something I have a propane line at the rear of the camper for hook up of barbecue I bought the hose hooked everything up the line is turned on but I cannot light the barbecue it's like th...
C Schomer wrote:
pressure.
You can remove the regulator on your grill and connect to the Rv 11” system but then you still need to control the flow/heat . Then you can try a needle valve and it still might not work. Craig
