profdant139's avatar
profdant139
Explorer II
Jul 31, 2015
Barnacles on my anode, but no erosion -- why?
I pulled the anode on my water heater -- the rod itself was perfectly intact, no erosion at all in the past year. But the rod had quite a few white barnacles. I s****ed them off easily with a knife. I assume those are calcium carbonate,
But how could it be that the anode did not erode at all during the last year? I have done a lot of camping and rarely, if ever, drain the water heater. I would have figured that the anode would crumble over time, but it did not.
Is there some electrochemical magic that is going on?
Thanks in advance for your thoughts!
Edit -- the website blocked out the word "slice," which is to cut with a knife. Very odd.
  • jplante4 wrote:
    GMandJM wrote:
    The NaughtyWord Editor has been quite the over-achiever lately. Sliced? Really???
    S C R A P E D - no C R A P on this website. ;)
    Oh good grief! That is just silly!!! Almost as silly as Pe****ch (Pet Watch) being naughy-fied.
    (Thanks for the clarification.)
  • Yep on aluminum. I had to replace my rod once a year. Then I bought one at a flea market. Never would wear down. Then I heard about the aluminum vs. mag deal. Made sure I bought a mag rod and stuck it in. Gone in less than a year. Bet the flea market guy has no idea what he's selling. No rod required in my present trailer, less to worry about.
  • I had 8 years on my last anode and it was still in good shape, I always wrote it off to rarely turning on the water heater. Maybe once a day for 4 or so weeks, maybe less.
  • Get white build up on my rod, is important to match correct rod with heater and make sure not too much tape so connection to tank is not made....good luck I would not overthink this, just do it according to instructions....if you like to do stuff put proper amount of vinegar in tank to flush it clean like a coffee pot.....
  • The NaughtyWord Editor has been quite the over-achiever lately. Sliced? Really???
    Anyway....
    The anode on our 2012 ViewFinder was aluminium and presumably your FunFinder's is the same. Ours didn't show much deterioration..a bit of pitting IIRC.
  • Old-Biscuit wrote:
    You are using an aluminum anode rod which has a tendency to collect 'stuff' and does not dissolve as easily when water quality is good
    Magnesium is the alternative......it is higher on Galvanic Scale but will not last as long.
    Course if the aluminum is lasting toooooooo long is it really doing any protection???
    X2
    somewhere on suburban instructions they say to start with the magnesium one and if it doesn't last a year then go to alum. (found it, and just passing it along. Nothing dated that I see, so I have no idea how old this info is or correct)
    "Anode Rod Facts
    Everything you wanted to know about anodes rods…
    Self sacrificing anode rods are placed inside water heater tanks to
    protect the tank from electrolysis, not to purify the water.
    Anode rod life is affected by the makeup of the water. Softer water or
    water with lower resistance causes the anode to self sacrifice faster.
    Suburban offers 2 types of anode rod material, magnesium
    (standard) and aluminum (optional).
    Anode rods should last at least a year. If the magnesium rod does not
    last a year, you should switch to the aluminum rod which is harder
    and does not self sacrifice as fast as magnesium.
    A byproduct of the anode rod self sacrificing is hydrogen gas.
    If there is high amounts of sulfur in the water, the hydrogen gas will
    mix with the sulfur to create hydrogen sulfide (rotten egg smell). You
    may want to use the aluminum rod to reduce the amount of hydrogen
    gas produced.
    The rotten egg smell can also be created by dead microorganisms in
    the water. Adding a small amount of chlorine to the fresh water
    system will kill these microorganisms.
    Anode rods effectiveness is not reduced by using Teflon tape to seal
    the threads. You should always use a thread sealant approved for
    potable water.
    Removing the anode rod to install an optional electric element voids
    the Suburban limited warranty.
  • You are using an aluminum anode rod which has a tendency to collect 'stuff' and does not dissolve as easily when water quality is good
  • Somebody with a good chemistry background will hopefully give a definitive answer. Pending that, my opinion is that it all depends on the chemical composition of the water in the tank.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
