DrewE
Sep 05, 2015Explorer III
I assume you have a centralized fuse panel for the 12V circuits? If so, that's connected to the positive battery lead, and that's where the fuses are. You can verify by removing the fuse for the fan circuit.
More generally, the best way I know to determine which lead is fused is to find the fuse and remove it and see which lead is now dead. That said, it should always be the positive lead, as close to the battery or distribution point as possible, and the fuse sized according to the wire size (or possibly smaller in a few cases, but never larger).
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
