path1
Sep 05, 2015Explorer
SCVJeff wrote:path1 wrote:What I would do is head to Harbor Freight or Sears and buy a digital volt meter. Why are you fiddling around without one?
I want to confirm my wires are fused is on the positive side.
Vent fan in bedroom pos is gray and ground is white. At other end of TT white is pos and gray is neg.
I can live with wires changing colors behind the walls or ceiling but want to make sure all fuses is on pos side. In case other projects or whatever.
How would you... test to make sure pos is the fused side?
How would a volt meter tell me which side is fused?
(edit part) posting above gives answer. Never knew about - sign on volt meter.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
