path1
Sep 05, 2015Explorer
Ava wrote:
Use a basic volt/ ohm meter and check the voltage. It will read the voltage either way but will show a negative sign in front of the voltage if you have the red lead on the ground.
Thanks you very much...I never knew that. Will be looking for minus sign tomorrow.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
