We just got back from a great weekend of camping, my only problem was the bathroom light would not work. Tried a new bulb, nothing, checked the fuse, it was fine, any ideas on this issue?
If it's the typical white plastic light, the switches on those go bad. When I bought my tt, I had to replace 5 or 6 fixtures that didn't work. Testing showed bad switches. Got new ones from Amazon for about $7.
You can pull the fixture down and using a meter, see if there is voltage going to the switch (when the wall switch is on).
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
