deprived
May 22, 2018Explorer
Bathtub rebuild drain issues!!
Okay. I messed up - I admit that.
I tore out the old shower in our 2008 Tiffin and replaced it with a bathtub. It was a huge effort that took several weeks to complete.
And now for the bad news.
The new tub fills up with drain water from the bathroom sink because the new tub sits about three inches lower than the old shower. That little bit of difference is just enough to allow the sink to drain partially into the tub which fills up with about one or two inches of water.
I have two choices to fix this, as far as I can see.
1: rip out the new tub and rebuild the entire thing. Let’s call that plan “B”. Or plan “Z”. I really, really don't want to do that.
2: make the tub drain pipe a bit lower and plumb a new second line to the grey tank. This new line from the tun drain will drop down a few inches beneath the floor and enter the grey tank from the side rather than the top. This will diminish my grey tank capacity a bit but it’s still a hell of a lot easier and cheaper than undoing a month’s worth of work.
There are some issues with cutting a new fitting into the grey tank but I’ve see a few methods using ABS fittings and solvent-cements that seem to work well. That part is tricky but surmountable. Otherwise it is a fairly straightforward job.
I’m not saying this is a perfect plan (or even a good one) but I wanted to put it out there to see what you all might have to say in terms of other ideas or improvements to the plan.
I found a picture of the old drain, and I can see that it sits about three inches higher than my new configuration.
NOTE: my diagrams are not all that accurate but I think they illustrate my situation.
