marininn's avatar
marininn
batter charger drain?
I have a auto battery charger wired into the array. The 2-amp camper charger is just not enough to charge a battery, so I have a 10 amp hooked in.
My question, does current flow backwards through the DC side of the transformer and drain power?
When I turn the charger off I assume all it does it disconnect power to the AC side of the transformer.
If you know I would like to hear, if you don't then you don't so no comment needed.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 17, 2025
