Huntindog
Apr 09, 2016Explorer
mlts22 wrote:
Right after each other, both the recoil rope broke and the starter battery of my 3000 watt Yamaha generator died. Rather than disassemble the darn thing to get a new pull rope added, I went and replaced the battery with a Yamaha motorcycle battery, which fit in perfectly, and had the same amp-hours as the old one.
Oddly enough, the box shipped with the battery, and a row of six vials of acid attached to each other. To get the acid in the battery, one pulled a sticker off the battery, turned the acid vials upside down, placed it over the row of holes on the battery, pressed to punch the foil seal on the vials, squeezed the bottles so the acid drained completely into the cells, then yanked off the row of vials, and then pressed a cap that spanned all six holes into place.
Took a few minutes to do, and even though the operation was fairly safe, playing with battery acid in the middle of the woods isn't my idea of a good time, even with making sure I had access to water and was wearing eye protection.
Is shipping acid separately from the battery something new that battery makers are doing? This is the first time I've seen this.
This is pretty common. You can buy the ATV batteries dry or wet. When buying wet batteries the date of manufacture is very important as the battery starts to degrade from the day the acid is added.
Dry batteries can be stored indefinantly.
I carry spare dry ATV batteries with me.My ATV batteries have a nasty habit of failing on a trip.
Since I am usually in a remote location when that occurs, having a new battery on hand at all times is the best solution for me.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
