theoldwizard1
May 16, 2018Explorer II
TomG2 wrote:
I was surprised and disappointed to discover corrosion on the terminal of a lightly used AGM battery. (Positive terminal only)
Corrosion around the terminals of any type of lead acid battery is caused by gases leaking out around the terminal. A thick coating of grease around the terminal will prevent this. Clean the entire outer battery with baking soda and water and rinse with water before applying the grease.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
