TomG2's avatar
TomG2
Batteries and Vaseline
Anything wrong with the old habit of using Vaseline (Petroleum Jelly) on battery terminals to protect them from corrosion?
  • marcsbigfoot20b27 wrote:
    In my case I just went with AGM. No more water checks or corrosion.
    I was surprised and disappointed to discover corrosion on the terminal of a lightly used AGM battery. (Positive terminal only)
  • No problem. Pretty much any grease will work. Be liberal ! Best to remove the cables and do around the the posts and then replace the cables and do them.
    I don’t see a problem with that or spray on battery protector.
