wa8yxm
Jan 03, 2021Explorer III
Oh and balancing is only important when you are sucking hundreds of amps (or pushing) and even with a 2000 watt inverter at max load you won't bother the batteies the way you have 'em.
So what happens if the batteries on say the left provide 34% of the power (33+33+34=100 percent) as they discharge the voltage will drop every so slightly and the other one of the other two will provide that extra percent. So all batteries will be so close to each other in State of Charge the difference will not be something you can measure.
Now at around oh say 500 amps. THEN you might be able to notice differences.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
