Gdetrailer
Jan 04, 2021Explorer III
Mike134 wrote:wa8yxm wrote:
Oh and balancing is only important when you are sucking hundreds of amps (or pushing) and even with a 2000 watt inverter at max load you won't bother the batteies the way you have 'em.
So what happens if the batteries on say the left provide 34% of the power (33+33+34=100 percent) as they discharge the voltage will drop every so slightly and the other one of the other two will provide that extra percent. So all batteries will be so close to each other in State of Charge the difference will not be something you can measure.
Now at around oh say 500 amps. THEN you might be able to notice differences.
Sounds like you've seen a phone companies power supply room as I have. There are literally hundreds of batteries connected in series parallel to give you 48V. Doesn't seem to be any issues of the batteries being "balanced" If I'm the OP don't lose any sleep about it. Your system will work fine.
X2!
Yeah, there are lots of obsessed folks that have NEVER seen a REAL battery "powerhouse" in use.. Worked for a place that had a dedicated "battery room" for their multiple 25Kw three phase "UPS" units (they also had redundant UPS units that would auto change over in case of a fault).. The battery room was 20'x30' and there certainly was not ANY "balancing" going on there.. The UPS system not only ran the computer room mainframe but the lighting and A/C units that were needed to keep the mainframes cool (mainframe was on a "false floor").
The huge UPS system was in place to give the 50KW three phase Diesel gen time to start and stabilize before transferring from UPS to gen under power outages.
Doubt the typical "RVr" is gonna draw enough or charge enough to cause enough "imbalance" to cause any "measurable" damage to their system to warrant obsessing over this subject.
