tenbear
Oct 27, 2013Explorer
tvfrfireman wrote:tenbear wrote:I will check into this tool. I am pretty sure that the drain must be the hydraulic system as one other person with same brand has the same problem on the DRV forum. The only thing hooked to the battery is the hydraulic system. I don't understand why so many things are wired upstream of the 12 volt cut off switch.. Thanks for you response..
Time to invest in a clamp-on ammeter and see what the drain is.
I should have mentioned, be sure you get one that measures DC current. Less expensive ones may only measure AC current.
