tvfrfireman's avatar
tvfrfireman
Batteries losing charge while in storage
My four six volt AGM batteries are losing there charge while the trailer is parked in storage. I disconnected all the wires from the positive terminal but still find them slowly discharging. In a second compartment I have to more batteries and noticed a wire from the positive terminal that goes directly to the hydraulic pump that is used in the level up system. Could this be draining the batteries? I have the trailer up on all 6 jacks to unweight the tires while it is not in use and am wondering if I should disconnect this wire from my battery. I have a 12 volt disconnect switch but it is down stream from t his hydraulic pump. Thanks for any tips....David
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
