MEXICOWANDERER
Oct 28, 2013Explorer
The Delco 11880 solenoid has silver inlay contacts. You lucked out. Drain your house batteries down, start the engine on fast idle, then take voltage readings.
At the alternator. From battery stud to case ground.
Across the battery lead posts.
Across the battery isolator solenoid, post to post.
What do you get?
I accumulated a 5 yard dumpster's worth of solenoids that were burned out via their power contacts.
What do you get?
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
