MEXICOWANDERER
Oct 28, 2013Explorer
Yes I autopsied too many to count. Drilled out the spot welds holding the lid to the can. Many died because they were junk to start with. A quick and dirty lesson. Solenoids must use a spring to pop the contact disc (copper) away from the two stud contact points QUICKLY after the solenoid is de-energized. If the disc lollygags it's going to get burned all to hell. OK a strong spring means a strong magnetic field is needed to overcome the spring tension then clamp the disc hard against the two copper studs.
A lot of magnetic energy is needed. Not just amps. A solenoid can be wound two ways. One is with fewer turns of lighter gauge magnet wire the second is with a lot more turns of heavier gauge magnet wire. Both may yield a resistance of let's say 7.0 ohms when measured with a meter. But electromagnetic coil winding function is a measure of AMPERE TURNS. Turns of wire. A "heavily wound" magnet coil may draw the same amount of amperes but have TWICE the magnetic pulling power. Yes, longer wire means more ohms (a higher resistance) but what happens when that "more wire" solenoid uses a larger gauge wire...the resistance difference is offset.
Think of a cheap solenoid as being "A Loose Connection In Sheep's Clothing".
Too many amps (watts) will overheat and burn out a solenoid coil winding. So this is why a Ford Type starter solenoid can carry 400 amperes - for 1 minute.
And too many amps will melt a solenoid's power contact disc and stud contact points. If the "connection" is loose as a goose because of a poor magnetic field then the solenoid went into my dumpster.
I found out the hard way that even small relays like the BOSCH (now TYCO) have many worthless junk copy-cats. Comparing a Bosch relay to a counterfeit is like comparing a Rolls Royce to a Yugo.
The newer "Tower Type" solenoids like the ESSEX are far superior to the earlier can type solenoids. They run cooler, use less current, pass more current safely and last longer.
Unless a Field Effect Transistor type power relay is manufactured incorporating a host of protective circuits (over, under voltage, transients, short circuit, reverse polarity and thermal shutdown, it cannot be as reliable and rugged as a mechanical relay. No way in hell. The insane amount of transient voltage spikes generated when a starter motor solenoid collapses the field inside a starter motor is the bane of any electronic device. DO NOT DO THE FOLLOWING! If a person should be touching a starter motor battery post connection when the ignition key is relaxed, the resultant transient voltage will knock them on their ass. It is far worse a jolt than a spark plug shock. It is not the POSITIVE transients that do damage in a starter motor circuit. It is the negative transients, and guess what...the ground side of a starter motor is not switched.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
