ken_white
Oct 28, 2013Explorer
MEXICOWANDERER wrote:
...Unless a Field Effect Transistor type power relay is manufactured incorporating a host of protective circuits (over, under voltage, transients, short circuit, reverse polarity and thermal shutdown, it cannot be as reliable and rugged as a mechanical relay. No way in hell. The insane amount of transient voltage spikes generated when a starter motor solenoid collapses the field inside a starter motor is the bane of any electronic device. DO NOT DO THE FOLLOWING! If a person should be touching a starter motor battery post connection when the ignition key is relaxed, the resultant transient voltage will knock them on their ass. It is far worse a jolt than a spark plug shock. It is not the POSITIVE transients that do damage in a starter motor circuit. It is the negative transients, and guess what...the ground side of a starter motor is not switched.
The newer FET designs are very robust, as are all of the electronics in newer vehicles.
I have had FET battery Isolator devices for years in a few different campers and never had any issues - no contacts to burnish...
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
