MEXICOWANDERER
May 19, 2016Explorer
Volt drop. Measure at battery post with red probe, the clamp with the black probe. This is how the pro's do it. The test is absolutely infallible. Keep tracing down-line to the load. The circuit needs to be under load for the volt drop test to work. Carry 90 grit sandpaper to scratch through the corrosion for the probes.
You can bet your sweet --- this test will find a bad post to lug connection in .001 second flat.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
