RVimana
Jun 09, 2016Explorer
Hi All,
First of all, thanks again for the help. It is sincerely appreciated.
I have an update, and even a couple of pics this time.
After the last update, I hadn't had any issues - until today. Hooked up the boat and took it to the lake (not far, perhaps a mile). Pulled in, shut the RV off, unstrapped, then launched and parked. Noticed it looked unusually crooked (one parking line straight, the other crooked - go figure). So I went to start it to move it...
No deal.
Won't crank but a second, then nothing. No lights, no power. Went fishing. Missed a biggun on a frog, but I digress...
Now, back to the ramp. Get in and turn the key, zero. There is this button on the dash, right next to the ignition, that says "Emergency Start". I push it, let go, turn the key. Nothing. I leave the key in the "ON" position, and push the button. All the 'check engine' lights light up (remember this is a 1988, i.e. choke. etc.). Let the button go, turn the key, nothing.
Now, I push the button in, hold it, and turn the key. RV starts right up. I leave it running while I strap everything down and get home.
At home, I park it and shut it off. Pull out my battery tester and find that the cranking battery (#1) is now a bit low. I switch it out with the same battery that I had used in my initial switch (it checked 12V+).
Get in and try to start it - nothing. No lights - zero. Push the emergency start button, hold it, turn the key and it starts right up.
Now, I leave the lights on and am shaking wires looking for a flicker, flash, anything that will tell me it's a wire.
NO KEYS in the ignition - push the emergency start button - all the lights come on. Nice and bright.
I've attached a picture of the wiring of the emergency start switch. I don't want to start unscrewing things until I have a replacement - could it be one of these solenoids? Is this a relatively standard item that I can get in an electronics store or RV dealer?
Thanks again for any more insight into this. I hope my info is helpful.
In friendship & safe travels,
EZ EEE
No deal.
EZ EEE
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
