RVimana
Jun 11, 2016Explorer
Hey All,
Took apart the connections on the top solenoid - both sides where the battery cables come in. Cleaned them with a file, re-connected. Same problem.
Took apart both sides of the lower solenoid, and noticed that the right side post was kind of floating or loose in there, while the other three were tight. Reconnected. Same issue.
Going to get a solenoid and switch that out (will at least have a spare) and check the other points that everyone has suggested as well.
Thanks again,
RVimana Erich
Thanks again,
RVimana Erich
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
