cjb2017's avatar
cjb2017
Battery and Quick Disconnect Question
Disclaimer: I'm new to camping...bought my first travel trailer 2 months ago.
Question: If I remove the battery quick connect/disconnect, does this remove all draw from the battery? I am under the impression that it does.
I pull the disconnect when I store my camper with the intent that it will be (rather) fully charged for me to pre-cool my propane refrigerator for the day or two prior to my next departure.
A few weeks ago...Not knowing how long it takes for my refrigerator to cool down, I engaged the battery connect/disconnect and lit my refrigerator 3 days in advanced. I checked on it each day and it was cooling quite nicely. The morning of departure, I opened my refrigerator door to find a warm unit. I only assume the battery was drained by then and thus the refrigerator could not operate. Does this sound correct? If so, any advice? Turn on refrigerator the night before rather than a couple days? Could it have been something else (a storm the night before...could this have blown out the flame and for some reason it did not electronically re-ignite?)?
  • “Question: If I remove the battery quick connect/disconnect, does this remove all draw from the battery? I am under the impression that it does.“
    When turned off mine does except for the tongue jack...self installed. If your’s is factory installed you’ll need to trace wiring and test. What brand and model is your TT? Someone might know. A solar panel would have kept your batteries up.
  • Also, my service guy tells me that even when the battery is disconnected, my battery is still being drained by my LP detector. Does this sound right? If so, maybe I need a battery charger to re-charge my battery after it sits for a bit?
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 10, 2025
