tenbear
Aug 04, 2013Explorer
Wendy Sue wrote:
yes tenbear but all the 12v lights work we are plugged into shore power and there has not been a battery on this camper since we have had it.
Yes, the lights work so the converter is good. If the empty fuse holder is in the +12v line from the converter it was probably removed to protect the converter. The fuse will have to be replaced before you will be able to measure the voltage on the battery wire to determine which is the positive wire.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
