BoonHauler wrote:
Well after trying a crimp on a 4/0 cable (welding wire) with a 4/0 lug I could pull the lug right off the cabling with my hand.
Did you try any different 4/0 cable?
I wonder if the cable and lug need to be matched up?
For example in the chart here :
Wire Stranding Chartsthe 4/0 wire thickness (- Last page - I'm assuming they don't consider the cover with these numbers...) goes from .504" to .666". I don't see how the same lug can work for all those thicknesses.
Is it possible the the wire, lug and compression die all need to match?
