westend
Dec 16, 2013Explorer
How are you measuring state of charge, with a meter? You can't send too much amperage to the AGM with that charger. Voltage, though, could be an issue. I wouldn't push it with anymore than 14.8 V.
If your charger has a 6V setting, you should be able to use the charger to charge a single 6v at any rate. You can charge or equalize two 6V's in series as a 12V, also.
Doh: Mena and I are thinking alike and at the same time:D
