landyacht318
Jul 22, 2015Explorer
Odyssey does NOT say to limit charging amps to 10 amps
They specifically say that their batteries require a 40% charge rate when deeply cycled.
http://www.odysseybattery.com/documents/us-ody-tm-001_0411_000.pdf
40 amps applied for a single 100AH battery until 14.7v at 77f is reached and then hold 14.7v for 4 hours while amps taper to the sub 1 amp range.
10 amps. Phooey.
Lifeline recommends 20 amps minimum for a 100AH battery when deeply cycled, and thei rupper limit on amperage is something ridiculous like 350 or 500 amps
I wish this trickle charge mentality would climb back in the insane asylum with the old wives and their crazy tales.
10 amps. Phooey.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
