bigfootford
Jul 22, 2015Nomad III
Lifeline batteries for RV and Marine are the kind that you can really shove the current to them if you have the proper charger.
My 100ah lifeline is over 7 years old and it sees 60 amps when discharged down to 60%soc. and stays over 45amps for well over 45 min... I have used a Progressive Dynamics 9260 for about 10 years now... I do have 200watts of solar to charge when on the road.
I am running a total AH using my trimetric... Currently over 5000ah cycled since my lifeline was installed.
UPG, Universal AGM 100 ah batteries state right on the battery not to exceed 35 amps..
I tested one in real world testing and it died in less than 2 mos.. I was told that disregard the 35 amp thing, use your 60 amp charger and have at it.
http://upgi.com/Products/batteries.aspx?cat=12
Charge Method (Constant Voltage) Cycle Use (Repeating Use)
Initial Current 33 A or smaller
Control Voltage 14.6 - 14.8 VFloat Use 13.6 - 13.8 VControl Voltage
Terminals
So I think buyer beware...
Everyone I know that has lifelines are happy campers...
Jim
Terminals
Jim
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
