MEXICOWANDERER
Apr 02, 2015Explorer
Someone want to offer senor DAS26miles that link to the MPJones Associates power supply brick?
An automatic TRUE battery equalization device remains as elusive as a pill to tame PMS. Connect the 16.0 volt power brick to a timer then start out with 3-hours then a shutdown. One power brick per 100 amp hours of battery capacity.
Only a hydrometer can tell you if and when the battery needs to be equalized and if and when the unequal cells are finished and read evenly. I can no more equalize a battery without a hydrometer than you can drive wit your eyes shut.
Do a little research on this forum and look for "Top Charging".
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
