Sort By
- landyacht318ExplorerMy Meanwell rsp-500-15 can go upto 19.23V and output 41 amps.
I use it as a manual charger and adjust the voltage however the dang well I please. Was 127$ delivered last October.
http://www.mouser.com/ProductDetail/Mean-Well/RSP-500-15/?qs=8uyp%2Fy7yFW4u946GFlR%252b8A%3D%3D
I removed the tiny voltage trim pot and wired up a 10 turn potentiometer to easily change voltage.
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27969414/page/1.cfm
Not the solution for everybody, just an option to consider, perhaps. - MEXICOWANDERERExplorerSomeone want to offer senor DAS26miles that link to the MPJones Associates power supply brick?
An automatic TRUE battery equalization device remains as elusive as a pill to tame PMS. Connect the 16.0 volt power brick to a timer then start out with 3-hours then a shutdown. One power brick per 100 amp hours of battery capacity.
Only a hydrometer can tell you if and when the battery needs to be equalized and if and when the unequal cells are finished and read evenly. I can no more equalize a battery without a hydrometer than you can drive wit your eyes shut.
Do a little research on this forum and look for "Top Charging". - westendExplorerSome automotive manual battery chargers charge at 16V or higher, especially at a 40 amp setting.
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 11, 2025
