groundhogy's avatar
groundhogy
battery charger?
Today, the battery voltage is dropping. The RV is plugged in and the 120v Christmas lights are on. I dont think i hear the normal hum/buzz of the battery charger...
  • DrewE's avatar
    DrewE
    Explorer III
    It's always nice when it's a simple and straightforward and logical cause.
  • Circuit breaker...
    When I came home last night, the indoor/outdoor led Christmas lights were out. Rained all evening here. Guessing it was the light string.
  • Check the battery for fluid level, excess heat or 'boiling'.
    Assuming the battery looks fine, disconnect one cable and check voltage of the 12v system and check battery voltage after a few hours or next day.
    Post the results.
  • If it's a three stage converter/charger, the voltage will indeed change from day to day.
    To know what's going on, you need more than just to hear the hum from it, You need a volt meter. We also need more information like what RV you have etc.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
