RobWNY's avatar
RobWNY
Battery Charging
Probably a dumb question but here goes..When you have other things attached to the battery posts like an inverter, battery monitor etc. and then attach a charger to the battery posts or use the converter, do all the amps/power that are replenishing the batteries just go into the battery? What stops the juice from going through the other leads of whatever else is attached? Can damage occur to the electronics of those other devices? Like a back feeding situation? Every image or video you see on charging batteries, doesn't show anything else attached. It wouldn't make sense to have to remove everything that's attached every time you need to charge the batteries and then re-attach when done.
  • Generally, any charging will go to run things in the rig that are on with any amps left over going to the batteries. Same with solar controllers.
    If you are in a hurry, reduce loads on the 12v system so more of the charging amps go to the battery
  • Everything stays attached to the batteries. That is the proper design.
    No damage is done.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
