pnichols
Apr 20, 2018Explorer II
wa8yxm wrote:
Faster charge/Discharge. Well LIfelines. perhaps. but not the rest
"... Lifelines. perhaps, but not the rest" may not make electro-chemical sense - at least with respect to all AGM batteries having much lower internal resistance than liquid lead acid batteries.
This low internal resistance is most likely the main reason for AGM batteries accepting higher charging currents at any given applied charging voltage.
In fact many AGM batteries have internal resistance values similar to those of Lifeline batteries - some maybe even slightly lower than Lifeline's. Lifeline specifically mentioning their high current acceptance charging does not mean that other competing AGM batteries can't do the same. Other manufacturers just don't seem to make mention of it.
What we need is a comparison of charging current acceptance levels between several mainstram equivalent size AGM battery models under the charging conditions of "constant voltage - unlimited current".
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
