wa8yxm
Apr 22, 2018Explorer III
Whqt does 0.3CA mean.. The standard we use to rate batteries is called C/20 that means the battery's capacity (in amp hours) if discharged over a 20 hour period.
NOTE that some companies use different standards so as to get a bigger rating Example Wal*mart uses the "At one amp discharge rate" method. So a 73 AH battery has over 100 amp hours at that speed.. The faster you discharge, teh faster STILL the battery runs down.
0.3C means 30% of the C/20 rate
So if you have a battery rated at 100 Amp Hours (both G-27 and G-29 are in that range) your max charge rate is 30 amps or 0.3 times 100.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
