- sh410ExplorerA VOM will help. Put the VOM positive lead on the + post with the red cable hooked up. Put the VOM negative lead on the Black cable and if you see 12V+ on the meter then that is the negative cable. If meter reads zero then test the white cable.
- Greko6666ExplorerWell the says positive and black ground negative so it's only the white that iam not sure
- skipncharExplorerWhite is ALMOST always the ground wire on an RV. The black and red most likely BOTH connect to the positive side.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
