suprz's avatar
suprz
Battery corrosion? 's
I was checking the electrolyte on my house battery (interstate srm24)
And notice that the insulation on the wires have pulled back from the terminals and there is a lot of the green corrosion showing on the exposed bare wire. I know this leads to increased resistance etc... Bad, bad, bad.... How should I go about removing this corrosion without having to replace the wires?
I was thinking of maybe taking a razor blade and cutting back the insulation and getting to clean wire, clean the corrosion as best I can and re-insulating with shrink wrap? I don't have enough cable to cut and put on new ends
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
