DrewE
Jan 26, 2019Explorer III
A master fuse or circuit breaker or similar overcurrent protection needs to be near the battery on the positive side to protect the wiring in case of a short circuit (and hopefully prevent a fire).
A cutoff switch may be anywhere that makes sense electrically and physically for whatever you're shutting off. Obviously, if it's also serving as the circuit breaker then that constrains where it ought to be. Traditionally switches are placed in the positive wire, which under some circumstances can have a few advantages for things like working on the wiring system, as it tends to have fewer things live when shut off.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
