MrWizard
Jan 26, 2019Moderator
If placed in the negative/ ground
And is in the disconnect is being use
Then the ground path is broken , there will be NO zap
Positive is the common most used way,
But a single cable ground offers advantage , if you have several cables on the positive terminal
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
