valhalla360
Jan 27, 2019Navigator
amxpress wrote:
Distance shouldn’t matter. Mine is 6’ away from my battery.
You can debate if 6' is close enough but you do want it close to the battery.
A long length of wire opens the opportunity for shorting out between the battery terminal and the disconnect.
If you turn the disconnect on the positive side to "off" and the cable between the battery and disconnect chaffs thru on a piece of grounded metal...zap.
Mounting it close with a short run reduces that chance.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
