Bobbo
Feb 02, 2019Explorer III
Lynnmor wrote:beemerphile1 wrote:
On a trailer it must be on the positive and the breakaway switch should be wired prior to the disconnect for safety. Sooner or later the trailer will be towed with the disconnect open but the breakaway will still function.
Breakaway switches can malfunction, brake wires can become shorted, keys can be accidentally pulled and there is no fuse, so do you keep a wire cutter right there to quickly disconnect before there is a fire?
Now, you are being silly. Beemerphile1 is spot on. A disconnect switch, which is the subject of this thread, does not protect from any of the things that you mention.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
