marter's avatar
marter
Battery cut off
We just bought a 2013 Montana with a battery cut off switch or in this case a plastic key that you turn to off when you don't want the battery to get a draw. My question is should this also disable the landing gear and stabilizers? My battery keeps drawing down even with the switch turned to off. Nothing inside the camper works even the LP gas detector is off so I am making an guess that the control box is still powering up to get power to jack system. It is quite a draw as when I connect the battery I get a pretty good spark. anyone have any ideas?
  • Usually landing gear, slide rooms, electric tongue jacks and that SORT of equipment are wired directly to the battery with a fuse or fusible link in the line. Those TYPE of items rarely draw any power unless you are actually using them.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
