2 1/2 yr old 12v battery that has had good maintenance. Took rig to the shop for some routine maintenance on other systems. Battery read 12.8 . Today (5 days later) battery read 9.8v. I've read on ...
Every time you discharge a battery, even a little bit, it is "damaged" in the form of reduced capacity. Deeper discharges or longer periods without recharging result in more capacity loss. Eventually the capacity is reduced so much you feel the need to replace the battery. That day will come a little earlier than if the battery hadn't been discharged so deeply, but you may never even notice the difference.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
