KD4UPL
Jun 12, 2022Explorer II
The 10 amp fuse you pulled is likely for the break away brakes. Put it back.
A negative disconnect will probably also disable the break away brakes so you can't pull the trailer on a road with it turned off.
I'd just use a circuit breaker in the positive main wire.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
