lakeside013104's avatar
May 30, 2016
Battery disconnect question
When the disconnect is pulled out (turned off) what electrical equipment should work inside the camper, 12V, 120V, or NOTHING?
When my switch is pulled, everything works as normal. The wire leads are connected to both terminals of the switch. Maybe I have a bad switch?
Lakeside
  • First off if the trailer is plugged into 110volts all systems should work. If not plugged in to 110volts only the 12 volt systems will work until the battery disconnect is turned off. If wired correctly all 12 volt power will be removed from trailer.
  • Don't know what FW you have, but the disconnect switch should kill most everything inside. A few emergency things, such as LP/Co detector, emergency weather radio may still work.
    If actual battery cable is disconnected, nothing will work.
    Above assumes you are not plugged into shore power.
    Jerry
  • If your battery is disconnect and you are not hooked up to 120 volt power nothing should work.
    Switch is either bad or not hooked up properly.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
