MrWizard
Apr 07, 2019Moderator
can you bypass it sure
but i would go looking for what is missing
i think you dropped a wire that is supposed to be on there, or you broke a small wire internally
the fact you can jumper the solenoid and get a click
means no power to the switch
or the maybe the switch died
second thoughts
are you 'sure' you put the batteries in with the correct wiring and polarity
(2) 6v in series, (2) 12v parallel, or you end up with 24v..oops
trailer RV ?
white wire is ON Neg/grd
blk wire on Positive/hot
second thoughts
trailer RV ?
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
