BFL13's avatar
BFL13
Explorer II
Oct 08, 2020
Battery Draw Bogus Math? Peukert UPDATE 2
Update- 11 Oct 20, Update 2- 12 Oct 20
Thinking one 100AH battery that can be drawn down to very low SOC gives you nearly the same "usable AH" as two regular AGM or Wet batts, as seen advertized, is bogus ?
What about Peukert? If you pick a steady amp draw like 5 amps, then that is the 20 hr rate for the 100AH batt, but is only half the 20 hr rate for the two 100s. So you would get way longer time at 5 amps with the two 100AH batts.
It is bogus to advertize that you get nearly the same AH because you can draw the one batt down so low but the other two are limited to 50% SOC using good practice. That is only because you are comparing 5 amps with 10 amps for the draw.
A "usable AH" is a clever invention indeed. :(
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
