1L243's avatar
1L243
Explorer II
Jan 08, 2015
Battery Equalization
Who does it?
What is your method?
  • What PD converter does 14.6? Perhaps the above is a typo for 14.4?
    Yes, I run Equalization size voltages on mine to get the SG up to true full SOC. That is a different purpose from getting all cells equal in SG, but uses the same method.
  • I do it. I have upgraded my converter to a progressive Dynamics (14.6) but I have a actual battery charger that will equalize at 15.3
    Recently was dry camping for a couple weeks would usually run the gen an hour or so and charge and run her hair dryer etc. After 2 weeks I ran the Quick Charge brand battery charger for 2 back to back cycles for eq. SG came right up.
    I also have a Mega Watt 30 power supply that I play with and will sometimes hit batteries with it. 15.4 ish volts
    It has now sat a few weeks with very little use when I go check it in storage and battery main switches off and sg is still up.
  • Hi,
    I allow the Blue Sky controller from my solar system equalize the bank every 30 days.
  • Not if you spell equalization "eqaulization" Well I think after reading some of the past comments, I will just let my batteries sulfate!
