Old_Islander's avatar
Old_Islander
Battery Failing Prematurely
I bought a 100 amp hour deep cycle battery about 18 months ago, and it seems to be failing. It will only remain above 12 volts in the camper, for about 12 to 14 hours, with normal camper use. When it was new, it would last for 2 or more days. This is without using the forced air furnace, but water pump, lights, (and all the background circuits -- alarms and so forth...) I generally run the happijacs and slide-out with the truck engine running.
I charged -- then disconnected the battery last fall -- in April it was still very close to 13 volts, so it held it's charge well over winter. I'm wondering if I have a short somewhere in the camper that is sucking the battery down?
How do you measure the resistance of the camper's electrical system? I have a pretty good ohm meter, but don't know what settings to use, or what to look for. I guess I'd check the various systems of the camper, by measuring resistance at the battery cables, by removing all the fuses, and then inserting them one by one, and checking resistance for each?
Is there a definitive test for batteries, that will measure their ability to last under load?
Any advice will be appreciated.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
