time2roll
Nov 25, 2020Nomad
With the sudden drop in voltage cutting out the fridge I would have suspected you to measure 10.5 or less volts as I believe the fridge should operate down to this level. I would keep an eye out for a loose connection by measuring voltage at the fuse panel or at the fridge itself. Nothing should complain at 11 volts let alone 12.1+
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
